Won't Start
blackadarn
I have 2001 gmc 1/2 extended cab 4.8. I stop at a friends and when I went to leave the truck won't start. I turn the key and all the lights work, but it will not roll over. Could it be a relay or the sercuity engauged. I cleaned all the terminals even the starter but no luck. How do I restet the sercuity?
Thank
Neil
Hey man how do you know i has gone in theft mode?
It could be ignition switch too.Or loose conection,hope your park/neutral switch is not causing the problem.
Let us know what you found.
I don't konw if it is the theft or not. I was just reading some of the other post and seen it was refered too. Why do you say you hope it is not the park , neutral switch? If I put a scan tool on it will it tell me even if won't start?
My truck came with a aftermarket remote installed. I hear this is not a good thing and that this could be the problem. Did anyone else have a problem with a aftermarket remote. I am trying to get some ideas before I drive out to check more things.
If you use vetronics corp scan tool,which is dealer tech,it will only shows if dtc's are stored in any controllers,it will also show you the data,which you have to compare with good and same vehicle data with you truck to see what is going wrong.
Why i said park/neutral switch is sometimes we don't even think about small things,check ignition switch too.the truck wont goes in theft mode unless someone fiddle it with diffrent keys.on some vehicles if vehicles goes in theft mode you can crank it,but you wont get injector pulse to run the engine.
Regarding you aftermarket remote,it has nothing to do with engine cranking.It has link with only remote control door lock module.
Thank
Neil
2003 silverado 2500 hd, same problem intermittently for 6 mths. turned key, dash lights work, doesn't turn over. AAA said battery was fine. Next morning ran ok. read manual, to reset security, step outside truck, press lock/unlock simultanously 15 seconds, security will synchronize. first time it worked. However, four weeks ago and again today, same problem. A friend told me they had same problem and changed fuel pump/filter; no more problem. I may try that. may be a switch connected from passlock security to fuel pump. No one can steal truck by using other key. Passlock only recognizes a certain key. don't think my problem is security.
The problem was a terminal rotted off of the solenoid. I could not see it till I dropped the starter. Hope this helps anyone else. Solenoid only cost me $29 Canadian. I live in Nova Scotia.
Neil
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,209 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
