Do I Hear My Fuel Pump While Driving
I know this is the kind of question you truck experts hate. It's from a truck newbie and it concerns a noise! I know you can't describe a noise right, but I'll try anyway.
While driving under normal conditions, but most often when the engine hasn't warmed up much yet, I always hear a rotating noise, speed-dependent, coming from the rear of the truck a bit more on the right than left. It's a 2002 GMC Sierra 2500HD duramax. I bought it used in 2005 with 45,000 on it. I tow a travel trailer a lot, and it has 113,000 on it now.
The noise has never turned into a problem and I'm not worried; just curious. I don't know squat about how it's put together, so I have no idea at all where the fuel pump is. I wonder if it's inside the fuel tank and that's what I'm hearing.
any thoughts?
Thx
any thoughts?
Thx
The truck has two pumps, an injection pump (on the engine) and a lift pump to move the fuel from the tank to the injection pump. You should not be able to hear the pumps with the engine running. I believe what you are describing is a wheel bearing going bad.
any thoughts?
Thx
+1 on the wheel bearing also but you said it does it when cold, you maybe hearing the allison whine as they do whine when cold but goes away after warming up but if your still hearing it it maybe the pump inside the tranny ready to go out.
You're hearing your Allison. They quit doing it now, but my first Duramax/Allison came with a video tape which explained several "sounds" which come from those beasts.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 383 Guests (See full list)
