Exhaust Question
I want to change my exhaust and not sure I want to pay 400-500 bucks for a full kit. I am looking at changeing the muffler and then dumping it right behind the rear axle. I was wondering what muffler you would recommend. I dont want alot of drone in the cab a little is fine. I was looking at the dynomax ultra flo.
2007 silverado 5.3L
You'll find tons and tons of threads on exhaust systems if you search. You can research the catback systems folks are buying as well and find out the size of their mufflers in the kit and then just buy that muffler. I did that with my Magnaflow. I really like it but I know Flowmaster, Corsa, MBRP(lately), Gibson(off and on), and a few others seem to pop up around here. I've added a few links below for you to browse through that have been around in the last couple of days.
Help Me Pick My Muffler
Fred 2 Now Has A New Exhaust
If you search, you'll find a TON more though with about every muffler manufactured listed on here at least once.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
