2000 Jimmy Bose Stereo Aux Input
kokesh
Hi,
I searched the forums about this already and got some helpful information but I want to make sure that the system will work before I lay down $60 for a GM harness.
I bought a Harmon Kardon drive and play system because I wanted to get rid of my FM mod for my iPod due to interference problems..the drive and play has an aux option which has the iPod connect to the stereo through RCA cables. Of course the stock stereo in my Jimmy doesn't have RCA inputs so I guess the idea is that I have to buy the GM9 aux harness. Now, my stereo is the Bose system made by Delco and the model number is 15755901. I took it out and I see the 21-pin connector and the 9-pin connector. The 9-pin connector is occupied and I'm guessing that the OnStar is plugged into this 9 pin connector. So my plan is to just take that out and plug the GM9 into this, then i can plug the RCAs into the GM9. Can anyone verify that this will work? (Initially I thought that maybe I could splice the RCA cables into the existing 9-pin connector that I have so I wouldn't need the GM9 adaptor..does this theory hold any water? A few people mentioned it in other threads but none of them seemed to have successfully done it.)
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
