2003 Suburban Keyless Entry Issue
ok...being a part of other forums, I've searched, but can't find the right answer
My key fob has apparently quit. I've tried changing the battery and reprogramming it, but no luck. I only have the one key fob because that's what was given to me when I bought it used.
Has anyone else ran into this situation?
I have a similar issue with my key fob. As it is getting older, it is wearing out, so the metallicized rubber pads that contact the little pcb board get dirty and don't allow a good connection. Try taking the fob apart and giving it a good cleaning with some rubbing alcohol.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,016 Guests (See full list)
