Helpfull Hint/ Door Locks
Here’s a little helpful hint, take it if you want it. Use your key lock on your door every once in a while. I have a 2005 Sierra, and luckily I was at home when this happened yesterday. I had locked my truck with the remote, when I went to get back in, the battery on the remote was dead. I went to use the key and the lock would not turn. Went inside and got the other key and had to force it a little, but got it to move. I then proceeded to spray some graphite in the lock. Once again this probably wouldn’t have been a real big problem on the road had my truck had TWO DOOR LOCKS, one passenger and one driver. Anyway figured I would let you guys know so it doesn’t happen to you. Take care, Jake.
Yep,I've always done this with every truck I had with keyless entry.
Its a good idea to "exercise" the key cylinder so it doesn't get rusty or "stuck".
I also occasionally lubricate it with a light oil (WD40,graphite,or a multi-purpose lube)
For her pleasure, or your's? I had to Rich :confused: .
I had that problem with my '02. In six years, I've never used the key to unlock or lock it. One day my truck battery died and I couldn't get either door unlocked with the key. Had to pop the hood from the outside, replace the battery, then unlock them with the remote. I ended up taking both door lock cylinders out and soaked them with WD-40. They were rusted pretty bad.
Ah.....Her's,Yeah thats it....Her's :confused:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 901 Guests (See full list)
