Upper Ball Joint R/r
dcmargush
1999 Silverado 2500 4x4 6.0L
I need to replace the upper ball joint on my passenger side. Is the procedure the same as if it was 2wd version.
Remove wheel, remove brake lines from upper control arm, loosen ball joint nut, use pickle fork to remove ball joint from spindle, remove upper control arm?????
I assume the ball joint is pressed into the upper control arm, is that correct? How is it removed from the Control Arm, pressed out??
Thanks
Doug
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 608 Guests (See full list)
