'07 Silverado
It's starting to get pretty cold now, and when my truck sets out with temps in low 20s it does not want to idle down when it reaches operating temp. I drive about 10 miles home and when I back in garage it's still running between 700-800 RPM. I can shut the truck off, start it back up and put it in drive and it will idle at 600 RPM. I have had it at the dealers and they downloaded some new software but it did not help. Any ideas would be appreciated.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
