Truck Not Locking Into 4wd Hi
jtkustomizer
I am new to this forum and I am having problems with the 4wheel drive in my 1998 GMC Sierra Z71.
The truck is not going into 4wheel drive like it is supposed too. When I put the key in and turn the truck on the lights on the switch all turn on and then go off after about 5-10 seconds. I can push the 4wd hi button and the both lo and high lights go on and blink continually and the truck doesnt lock into 4wd. If I push the lo button it switches into lo just fine and everything locks in like normal. but getting it back into 4Hi or 2wd takes a couple of button pushes.
I took it to a dealership and they told me the switch in the dash was bad and that the actuator in the front differential was bad as well. My dad has the exact same truck and everything works just fine on it, so I switched the switch and actuator out of his and into mine and it still does the same stuff and his is works just like it is supposed to. This issue has baffled me for a while now and since it has started snowing/ getting Icy 4wd would be really nice to have again.
Thanks in advance.
Hi there and welcome to GM Trucks! :dunno:
The switch and actuator going bad are pretty common. But since you've eliminated those, hmm. Have you checked the wiring between the switch and actuator? Other than that, the better experienced here will need to chime in.
I havent checked the wiring but when I had the actuator out I had my dad push the buttons and the actuator actuates while it is out just like it should. By the way does the actuator have to be lined up in a specific direction once it is installed or should it just be tightened like any othe nut/bolt.
I also tried 3 different in dash switches and they all do the same exact thing. I will take pictures/ and or video of what it is doing later tonight.
So you switched out the buttons and the front diff actuator; maybe you should switch out the TC encoder/actuator as well. I had to replace mine.
Is this the one located on the transfer case. Does anybody have a picture of this?
Yes, it's on the front driver's side of the TC. You need to remove the front driveshaft, 2 electrical plug-ins and 3 bolts. 10 minute job. :D That's how it is on my 2000. I'm thinking '98 ain't much different.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 602 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
