Camber Adjustment On 08 Silverado
Hello,
Has anyone had experience with the camber adjustment from this company (see the attachment) - ProRyde Suspension Systems They detail it in the installation instructions for the adjustable 2008 Silverado leveling kit.
They was a guy on here trying to sell that junk, the question to ask yourself is why do you need an adjustable leveling kit and why would you need an adjustable camber. Once you put in your leveling kit and get it aligned at the shop your done no more adjustments are needed by you. Also once you put in your leveling kit why would you want to adjust it up or down 1/2" or 1". Just go out and get a leveling kit put it on get it aligned and be done.
I was actually interested in the camber part to change the angle at which the upper ball joint is at. It looks like it will also change the position of the upper control arm relative to the spindle, moving it up from the factory stop.
I agree the adjustable leveling kit is not a good idea, no need for it.
I like that spacer, got any more info?
I don't have any more information than whats listed in the installation manual for the adjustable leveling kit. They don't even have it detailed on the website, they might still be proving it. I would really like to get feedback from someone on this part. It looks like it might screw up the suspension geometry between the upper & lower control arms.
Well if you find anything else on it report back, it appears it will help correct the balljoint angle of the UCA if you have a spacer on top of the strut.
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 588 Guests (See full list)
