99 Denali Heated Seat Question
ultara
I replaced the worn seats in my 97 Tahoe. It had power seats but no heated seats. I found a full interior from a 99 Denali at a junk yard. I now have power/heated seats (both front and back) but need advice on the wiring. The new seats will plug in (same plug configuration) but I have an extra small guage brown wire that I assume is for the heaters. I cannot find the appropriate wire schematic to identify the correct power source, if in fact this is a power wire. I am assuming this is a relay activation wire because of the small guage. I don't need to start a fire in my seat, so I am investigating before connecting. The wiring from the center council to the rear seat heaters is a problem for another time.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 534 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
