Shift Cable Replacement
How do I replace the shift cable on a 97 K1500? I broke the end of the plastic housing around the cable and now it won't shift into park unless I do it manually from beneath the truck.
If you have access to a Haynes or Chilton's manual, it will explain how to do this. It'd take me an hour to type it out for you. You can pick up a Haynes manual for less than $20 at Autozone.
