Dash Problems
I have a 2008 CCSB GMC 2500 HD 6.0, I have had problems with the volt and temp gage reading high. I know everything is working and the gages are just off. also my gear indicator and information center are not working all the time. has anyone had the same kind of problems
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
