Towing
montecarloman90
I was wondering if anyone knows what i would be safe towing with a 99 grand am 3.4v6. I would be towing to jetskis on a trailer jet skis weigh about 500lbs each so i would be towing 1000-1500. In the owners manual it says no more then 1000 lbs
I have a truck but i want to go up north a few times this year and take the boat to so would need something else to hauld the skis
thanks for everyones help
If there is a factory hitch on don`t go over what the manual says, if its an aftermarket one find out what its rated too. I`m sure it will tow 1500lbs but for how long....
I wouldn't do it. Not saying it wouldn't be safe. I just doesn't sound right.
Glad I could help :D
That is probably half the weight of your car. Not a big deal if you had to move it across town, but I think you would be taking a safety risk.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
