Unlock Radio In 99 Sierra
sonofasailor
I just replaced both batteries on my 2500 and now my radio is locked. I searched the forum and only found one thread that I wasn't able to access the links that were provided.
I read through my owners manual and it tells you to make up a code? Also when i push & hold the # 1 & # 4 at the same time nothing happens. However I get access to where you enter the 3 digit code by pusing HR or MN.
Any direction you can give me would be appreciated?
I read through my owners manual and it tells you to make up a code? Also when i push & hold the #1 & #4 at the same time nothing happens. However I get access to where you enter the 3 digit code by pusing HR or MN.
Push and hold the #2 and #3 buttons and hold for about 15 secs and it will display a 3 digit number, write it down, push the am/fm button and it will give you another 3 digit number, write that down. This is the 6 digit number you need to unlock the radio, email me that number or post it and I will call and get you a unlock number
I did as instructed and the numbers are 282 & 292
push and hold the #1 and #4 buttons then it should go to ----, then use the min/hr buttons and install this number 1185, then push the am/fm button, then it will rear SEC,
then turn on the radio, and your done
When I push and hold #1 & #4 nothing happens? Held for at least 30 seconds?
sorry, I was wrong (I haven't unlocked one for a while) just hit min button then 000 appears, use min/hr to enter 1185 then hit am/fm, then SEC should appear, then just turn on radio
Donnie,
Thanks for your assistance. I skipped the 1 & 4 step and went right to the hr & mn buttons. And Walla, I have tunes once again. Your the man. I will hang onto the code for future reference.
  • 2 months later...
    novdelta27
    novdelta27
  • Who's Online   5 Members, 1 Anonymous, 454 Guests (See full list)
