Random Cylinder Misfire P0300
I've had a cold starting problem with my 02 2500K Suburban where the engine starts fine and once the rpms go down it sputters and almot dies unless I give it some gas. I finally got meself a code reader and went to start it. The same thing sputters and almost dies, I did not give it any gas this time and it threw a code p0300 random cylinder misfire. I also noticed that the ignition advance was jumping around inbetween 10 and 30 degrees.
Now, any good guesses what's causing this? If this were an old car I'd say the distributor but what could it be in this case?
Have you cleaned out the throttle body? Sounds like that would be the thing to do first and it's cheap & easy to do...
Seafoam is the way to go for that. GM has their own version. If you do that then plan on it just before an oil change, because you will need to change the oil after the treatment.
Have you checked the fuel pressure regulator? It could be starving itself for fuel.
That I haven't done, what's the procedure for that?
I did clean the throttle body and the idle air control system.
Do a quick search on here about the fuel pressure regulator. It is very easy to check and there should be some easy step by step instructions inhere somewhere. This seems to be a fairly common problem.
Got this sorted out finally. The previous owner had skipped spark plug change at 100k and the truck has now gone past 130k. There was almost 0.1 gap in plugs and tips had gone down to almost nothing. New plugs + wires and all is well. Funny thing is that this only showed up once it got cold and only just after the startup, otherwise it worked fine. Live and learn.
Slainte, Riku
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
