Friend's Gmc Sierra?
Hello
My friend has a 2002 GMC Sierra with a 4.8 litre in it. He is wanting to know if this cam will fit in the his truck http://www.thunderracing.com/dynographs/?a...ead&pgid=94
But, he was told to buy the third one down titled "Old Man Truck Cam" Visit My Website
He has heard from some that the first linked cam will be fine and heard from others that it will not work.
So if anyone has anything to say like which one will be better or fit please share..
He is also planning to put on headers and a stall if the cam can work..
Thanks...
I like the TR220 better for that setup than the TR OMC. Have him order the 112+4 LSA version vs the 114LSA. It will boost cylinder pressure, DCR, and provide better midrange with little adverse affects. The 112LSA will idle a tad rougher and need more skill to tune but it's worth it. He'll want a 2400+stall and headers will help alot. Don't forget the tune. It won't run for crap without one.
Thanks for the reply man. Yeah he called TR and they said the OMC would be the only one that would work for his truck, but he's also been told that the TR220 would fit also. So he's indifferent about the situation. He plans on getting headers and a 2800 stall.
I'm not sure if I'm following you correctly on the 112+4 LSA version vs. 114 LSA.
What exactly does the +4 mean? And how is it different from the one that I provided in the link? How do you order it from them?
Thanks again man
I still recommend the TR220 112 with those intended mods. The +4 in relation to the 112LSA means it has 4 degrees of advance ground into the cam when ground by Comp for Thunder Racing. This lowers the effective powerband, provides a bump in lowend and midrange and increases DCR and cylinder pressure due to the valve events. As far as I know all TR's 112LSA grinds are ground with +4 advance so have him order the TR220 112LSA and be happy with the power. I used to run a TR224 112 in my 02 Camaro SS. It was a H/C car that made 420rwhp @ 396rwtq. Loved the power and driveability of the TR grinds.
Alright thanks for the quick reply man..
He's supposed to order the cam soon, so we'll see how it works out..haha
Also, how much of an improvement would he notice if he put a LS6 or LQ9 intake on?
Which one would be better?
Thanks
The GM truck intake is designed to build lowend and midrange power yet still providing decent topend power in the low 6000rpms range. The LS6 intake is the exact opposite of the truck intake. Above 6000rpms its all LS6 intake in terms of power production. Yet, IMO keep the truck intake. These trucks are heavy unlike a car and the truck intake is more suited for torque production which these trucks need.
Ok cool.. So how about something like a FAST intake?
Would there be any large improvements by adding that or not?
Also, what else would help gain power without being outrageously priced?
He's already got an exhaust and cai and is getting headers, cam, and stall..
Thanks
With his setup, rpm range and engine CFM requirement he won't gain much if any power with the FAST90mm to justify the $700 cost. Keep the stock truck intake and put that $700 towards a set of Stage 2 5.3L heads. Power is made in the heads and cam. Everything else simply supports it. For cheap he can port or have his stock 75mm TB ported. Usually 5-8rwhp gain if done right. I did mine myself. ASP 25% underdrive pulley. Another 3-8rwhp.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 655 Guests (See full list)
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
