'96 Chevy 1500 Abs Problem
amscontr
I have a 96 1/2 ton 2wd, first the airbag light would flash then the engine would stall cut out and the brake pedal would go to the floor. So I took it to a "reputable" shop and ask them to scan/check for codes etc. 500 bucks later it needed a tune up and speed sensor. After the repairs were done now whenever I come to a stop around 20 mph or so I hear a noise like a motor of some sort running or something, the ABS light comes on, and the red brakelight comes on sometimes. So I took the truck to another shop and had the brakes replaced and still the same problem.
Any ideas or suggestions??? Thanks.
Dont go back to those two shops. :D
The ABS module could be bad, or you have some electrical issues. You need to scan the ABS codes. It take a specific scan tool to do this.
I hear ya, no I knew it needed a tune up and brakes. But the speed sensor deal I don't have the equipment to check it out and luckily I have been busy working a lot. I just pulled the 60 amp ABS fuse for now. As far as a scanner would a dealer be the best place to get the correct codes or????
Yes the dealer is a good place to take it. Be in mind they do tend to charge more than the local shops. Try to get a quote before any thing is done regardless of where you go. Ask lots of question and take notes. Make sure you explain to them what work has already been performed.
On the bill/work order it says codes 35, 36, & 37 and they replaced the rear speed sensor if that makes any sense???
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
