More Blower Resistor Problems
-shaggy-
oh my god, even my own dealership cant find it, i have a 1LT packaged 2006 silverado, and even looking up my vin number they still order the wrong part? can someone tell me what the hell is going on and if i looked up the RPO codes would it help? if it was summer i wouldnt mind but riding around when its 30 degrees outside with not heater gets old fast. thx guys.
Replaced thge resistor in my 01 last month and the part the guy showed me was way different than mine, he told me they changed the disign. I installed it and it work good. Does yours has a green print board on it? If so, it is the same as mine was.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 461 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
