Camper Mirror Auto Dim?
My window sticker says the camper/tow mirror on the driver's side auto dims. I can cover the back sensor on the rear view mirror and shine a light in the front sensor and the rear view mirror dims but the camper mirror does not. I don't believe there's a separate sensor for the outside mirror to dim but I'd like to know how others' work. Has anyone figured out how their camper mirrors dim?
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
