Hvac Fan Squealing
The HVAC fan in my 02 has started squealing horribly whenever it is on.
The highest setting (5) is a little easier on the ears, but not by much.
My question to you guys,
Is the fan easily removed and lubricated? or will I need to source out a new one.
Thanks in advance
Easiest way is to just replace it. The fan isn't really very expensive and is easy to do. It's also not really a serviceable part.
anyone else able to provide some insight on this?
To Remove:
Remove the instrument panel sound insulator panel (if equipped).
Disconnect the electrical connector from the blower motor.
Remove the blower motor insulating cover screws.
Remove the blower motor insulating cover.
Pull the retaining tab down and rotate blower motor counterclockwise to remove.
To Install:
Position the blower motor and turn assembly clockwise until tab locks in place.
Install the blower motor insulating cover.
Connect the electrical connector to the blower motor.
Install the instrument panel sound insulator panel (if equipped).
Taking the glove compartment tray out as well can make it easier to access as well.
Otherwise it's about a 15 to 30 minute job to replace. :)
Had to replace mine back in december, it was so loud that i could barely hear the raido. It only took 10 min and the fan and moter was like $25 so just replace it.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
