5.3 Oil Pressure
dickey
hi im new to the forums but i saw an old post that described my problems ..when i cold start my 2000 z71 5.3 oil pressure comes up then drops off if i take it easy up to 1500 rpm then drive it easy till it warms up its good rest of day. like i said isaw old post where people were gonna try different things like o-ring on pickup and oil pump did any of these work cause i had my pan and pick up off cleaned with same result dont know what to do is it oil pump and is it hard do install on 5.3 thanks for any help :) PLEASE HELP
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 397 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
