99 K1500 Sub, Front Diff Whine/growl
Guys, two years ago i bought a 99 sub with 180000 miles on it. It has a new tranny and rebuilt transfer case. when i got home i changed all fluids. The rear diff fluid was definatly old but looked to still be okay. The front diff however came out like clumpy chocolate milk. I did a few flush runs and everything seemed to be okay. After awhile the front pinion seal started leaking. i popped the nut off and replaced the seal. Unfortionally i didnt mark where the nut was so i have no idea how tight to put it back on there. I set it to 150 ft/lb hoping i would be close. I believe after this is when we started noticing the whining/ mild growling only on decent with or without the brakes on. If you just let off the gas while you were going down the road you would hear this. Well i figured that maybe i didnt get it tight enough so i bumped it up to 180 ft/lb. It seems to be getting worse and worse. do you guys think that just getting a new crush sheeve will do the trick? Or does it point to a bad bearing?. i dont know alot about diffs so any help will be appriciated.
No, i dont have anything that will measure that small of a torque. I remember reading what it was supposed to be though. 5 ft/lb or in/lb? is that all there is to that? if i have it to tight, is it possible to just loosten it a bit?
Its been a while ,but 5-10 inch pounds is bout right.*edit, Dont quote me on it* No, once the sleave is crushed incorrectly, it must be replaced. Depending on how bad it was, you could of put too much load on the pinion bearing destroying it too.
this may be good news for me. i would love it if i could just replace the sleave and bearing. based on my situation explained above, does this sound probable. i was thinking i was looking at a full rebuilt, but this would be much better.
    ottogriffin
    ottogriffin
  • Who's Online   4 Members, 0 Anonymous, 678 Guests (See full list)
