2wd Lift Help..
Thanks to Dan, he gave me some insight on this topic (which I know gets discussed a lot, but not as much for 2WD).
2006 Silverado Hybrid Ext. Cab 2WD 16" wheels (boo) - Wanting to level the ride by lifting front end. Dan suggested coil spacers.
Questions:
- Do I want a 2" or 2.5" coil spacer to level it out? Have seen both, but didn't know which was closer..
- Will I be able to use my new Billet shocks safely with these added on?
- Easy install overall?
All I can think of thus far...thanks!
Bump w/ some new info and pics. Think it would look better leveled?
Stock ride height: rear measurement between tire and fender = 6 3/4" , front 4 1/2-3/4"
Leveled ride height w/ front measuring 6 3/4"
Is this what I can assume it will look like? I just need to know about the 2" coil spacer, if that will give me a true 2" lift...or opt for the 2.5"?
Also, I've seen 2 options...eBay Coil Spacer - Metal 2"
and Polyurethane 2" or 2.5"
Any additional help would be great, thanks!
I've got and 06 2wd, and wend with the Ready Lift 2" coil spacer. This isn't a great pic, but you get the idea
with the 2 inch it doesn't look full level, i would go with the 2.5s for sure....i dont think they will put the front higher than the rear.
I might need to redo the pics on a flat surface..I am parked on a small incline which may be deceiving. Thanks!
Completely off topic, but, what kind of mileage do you get with the hybrid?
Well, it's hard to say..they call my system a stage 1 hybrid. The truck is never propelled on electric, it only kicks in if I am braking under 12mph, or if I am idle w/ my foot on the brake. So, I am not really getting better MPG's, per se, but I am saving gas when you would normally get your worse MPG... I get close to 20mpg on the hway and 15-16 in town.
That sucks. I get that same milage and have no hybrid.
But, I also have a compressor wherever I go...start my truck, hold in a button that activates 110v mode (turns all the outlets on)...pull the key out, truck is still running on gas. Now able to use 110v plug ins that are located inside the cab and also in the bed of the truck for whatever I need! :jester:
    FiLo
    FiLo
  • Who's Online   5 Members, 0 Anonymous, 655 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
