Drug Rehab For Dukers
mattgob86
Yeah...this is definitely going to stay on topic. :rollin:
Sell the bong, papers, etc... Any time you feel like a toke, go for a run. Then congratulate yourself for not falling prey with something you like. This way you'll have both negative and positive reinforcement, associate weed with exercise and no weed with ice cream, food, "Palm"ela, whatever you want, if it's the later...we'd rather not know.
Pot isn't a drug, so if you're considering quitting, it should be easy enough to do. :rollin: I, on the other hand, like it every now and then. :rollin:
81 days tobacco free here!
Totally smoke free for the moment, but if i ended up near a bong, I'd chamber it and clear it so fast it'd make your head spin. (and mine too! :rollin:)
Pot isn't a drug, so if you're considering quitting, it should be easy enough to do. :rollin: I, on the other hand, like it every now and then. :cheers:
O'Rly? :rollin:
Pot isn't a drug, so if you're considering quitting, it should be easy enough to do. :rollin: I, on the other hand, like it every now and then. :D
O'Rly? :rollin:
:cheers: That's my theory, and I'm sticking with it. IMO, alcohol is more addicting than pot. When I used to drink, 13 year's of sobrioty next month, I had to have it. I don't have to have pot. I should mention that I don't pad the dealer's pocket either. :D
O'Rly? :rollin:
I agree Jeff. Alcoholism runs rampant in my family. My Dad and just about every one of my siblings has had problems, some worse than others. Luckily I never have, but I consider myself lucky. I have seen what damage alcoholism causes to a person's life and IMO alcoholism is FAR worse than being a pothead.
O'Rly? :rollin:
:cheers: That's my theory, and I'm sticking with it. IMO, alcohol is more addicting than pot. When I used to drink, 13 year's of sobrioty next month, I had to have it. I don't have to have pot. I should mention that I don't pad the dealer's pocket either. :rant:
+1 Have to agree with CC here as genetics on my Dads side of the family also contributed to all sorts of problems with alcoholism...his brother, some of my cousins, and even some of my siblings as well...in fact, I lost a sister back in 1993 because she drank herself into the grave... It caused much grief on my Mom and she was the strongest person I knew... :D
I remember rolling one like this back in '78, with the paper that came with Cheech & Chong's "Up in Smoke". :rollin:
:cheers: Ya, I remember in one of their comedy albums in the track titled "Let's make a dope deal" where the contestant is asked, "How many joints are in a lid?" to which he replies, "Two". The host says, "Two?" and the contestant says, "I roll BIG joints!" :rollin:
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
