09 Seirra Shakes Or Pulsate At Low Rpm
busabling
Hi im new to the board. I have a 2009 gmc seirra that pulsate or shake when I'm moving from a stop or coming to a stop. I only feel it at really low rpm. Once the truck get to about 2-3 mph, the shake goes away. Or once the truck comes to a complete stop it's fine. Truck has only 6k miles so I bought it to the dealer twice. First time they thought it was warped rotors so they turned them. I bought it back when i found out the problem was still there and the mechanic said he owns an 08 that's been doing the same since he bought it and it was ok. So now I'm here trying to get a second opinion. Maybe I'm just paranoid. Any help?
Btw it doesn't shake when in park, neutral or in drive as long as I'm at a complete stop. Truck is 1500 5.3L crewcab.
These trucks (and all trucks) are prone to a little driveline shake at certain speeds. It varies from truck to truck but all of them have it to some degree. Lots of time first time truck owners drive themselves crazy hunting things that are really just the nature of a vehicle that is designed to not only operate as a daily driver but also possess the ability to haul and tow very heavy loads.
As a long time truck owner of many trucks, I say unless you experience a worsening condition or it is accompanied by unusual noises, I'd chalk it up to being a characteristic of the truck. Especially if it goes away at 3 mph.
Thanks jim. U hit that on the dot. As a new truck owner we tend to go look for noises and problems. Sometimes just asking for it or opening cans of worm.
I'd be concerned about the rotors being turned when they weren't needed. Now your rotors are cut and will warp faster. I'd ask for new rotors since that clearly wasn't the problem.
And welcome to the site!
I complained about this to Justin while getting my Blackbear tune yesterday. He said that at low partial throttle, gm had th eoil pulsate to the torque converter. He made an adjustment for me that lessened it but it is not completely eliminated.
Not knocking you at all. It's just a very different thing to go from a car to a vehicle that is designed to haul heavy loads and tow heavy trailers. You have to realize that the unloaded suspension is going to cause some unwanted vibrations due to its stiffness. It's something you have to get used to as a truck owner / driver. Most of us really like the way a truck drives...
If the problem doesn't worsen, I say enjoy your new truck! :D
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,494 Guests (See full list)
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
    • Do you have access to BP fuels? Some stations have Silver 91 E-0 priced the same as their 93 E-10.  There is a local Marathon with 90 alky free for $6 a gallon but I go down the road to BP for $5-ish. They also have a 100 E-0 but that stuff is $10 a pop.
