Blown Rear End - 1999 Olds Bravada
So I blew the rear end in my Bravada this weekend... long story short a friend misdiagnosed leaking fluid from the driver rear tire as a bad caliper when it was a bad axle seal. rear end is toast, only had a few ounces of fluid in it.
Im just trying to get a ballpark figure of what its going to cost me to get it fixed. Most shops are between 50 and 70 per hour around here.
www.car-part.com
Search the junkyards around you for one, using the site above... I was looking for the same axle for my S-10 Blazer, and they were $250 everywhere, with a G80...
Takes about 4-5 hours for the swap, if you've never done it before, and take your time... cake...
Mike
www.car-part.com
Mike
Well, work is done. ended up being about $1300 for new ring/pinion, bearings and seals. Total bill ended up $1950, as the rear brakes were toasted because of leaking fluid all over them... dont know how long it had been leaking, but everything was soaked in grease. plus i was due for an inspection and needed some ball joints and front brakes (i knew i needed that).
total repairs were to:
front rotors and pads
upper ball joints
rear pads and rotors
ebrake pads
rear ujoint
backing plates
wheel bearings
ring and pinion
bearings
synthetic gear oil with limited slip additive
Hurt the wallet a little bit...
www.car-part.com
Mike
upper ball joints
ebrake pads
rear ujoint
backing plates
wheel bearings
ring and pinion
bearings
HOLY CRAP!
front rotors and pads - $100
upper ball joints - $50
rear pads and rotors - pads $30, no need for rotors unless they were warped
ebrake pads - ?? Maybe $30?
rear ujoint - $20
backing plates - included in axle swap, and probably not needed anyway
wheel bearings - included in axle swap, but I put outer bearings and seals in my S-10 blazer for $50 in parts
ring and pinion - included in axle swap
synthetic gear oil with limited slip additive - $10
Axle for axle swap - $250
Total: $490 without new bearings and seals in the new axle, or $540 with them... Oh, and a solid weekend's work...
Mike
www.car-part.com
Mike
upper ball joints
ebrake pads
rear ujoint
backing plates
wheel bearings
ring and pinion
bearings
HOLY CRAP!
rear ujoint - $20
Mike
I checked on alot of the prices, and they were right where they should be (taking into consideration mark up)... the ebrake pads were $125, even retail through advanced.
i do not have the skill, tools or space to do something like this, and a backyard mechanic is what got me into this mess in the first place!
