07 Nbs A/c Started Blowing Hot Air Then Normal
The other day while moving, I noticed that my A/C started blowing hot air and then went back to normal. Thought I saw something about this somewhere but couldn't find it. I think I had a similiar problem 2 yrs ago with the heater blowing cold. Anyone know what it might be? Have a 2007 NBS
Did you have the accelerator floored? Or driving up a steep hill and a big load on the engine?
These days the A/C compressor is routed through the engine computer and it controls it. In the past if you were at "wide open throttle" (accelerator floored), then the engine computer would shut down the A/C compressor to give you more engine power.
I don't know if they have added more situations to the newer vehicles which will shut down the A/C compressor?
It might say something about this in your owner's manual?
And if anyone has a factory service manual for this year, it may (or may not) list what situations the computer would shut down the compressor. Sometimes this would be in the A/C section "General Description" [of operation], or in the engine computer section, or buried in the troubleshooting flow charts for either.
I had a similar situation last year. My AC did the exact same thing you are talking about. It did this 2 or 3 times last summer. Then at the beginning of this summer, the AC wouldn't work at all.....it just blew hot air.
I found a broken wire on the high side pressure switch. The wire was broken right at the connector. These connectors come apart and you can solder the wire back together. Otherwise, the harness' are about $60 from GM if I remember right.
Not saying that this is the same problem you are having, but it sounds similar to what happened to me last year.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
