Window Sills
I just noticed today that the plastic molding on all 4 windows of my 07 extended cab silverado are coming loose. I don't know how long it's been like this, but they come right off, to where you can see all the way down into the door. Are these supposed to be glued in, or are there snaps ??
My 08 did that on the driver side door. They replaced it under warranty. It has some snaps in it and I guess they were stressed or something becaiuse they would no longer stay in place.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
