Im thinking about putting electric fans on my tahoe should I but a kit of can I go a buy two fans? what size you think I will need to get
  • 3 weeks later...
I can i get the electic fans off a wrecked newer chevy truck or SUV? What all I need to pick up and how hard will it be to make it work right. Or buy two fans from a parts store what size I need to get if I go that way
most people use the fans off of a LS1 camaro or Firebird and make a wire harness.
ok cool so they fit good has anyone wired one up so does one stay on all the time and the other comes on with the a/c or what
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
