Rear Drop Kit
WHATS UP GUYS? MAN, I FEEL LIKE I'VE BEEN LOST FROM THIS SITE FOR AWHILE.
OK SO I'VE BEEN READING THROUGH A FEW POST TO AVOIND THIS AND BASICALLY I'M JUST LOOKING FOR A STRAIGHT ANSWER.
i WANNA DROP THE REAR END 2 INCHES TO LEVEL IT OUT AND I'VE BEEN LOOKING ONLINE FOR A KIT AND CAN'T SEEM TO FIND ONE FOR AN 09 CREW CAB SIERRA. CAN SOMEONE PLEASE HELP ME OUT WITH A LINK OR SOMETHING?
WANNA DROP THIS BETTY CUZ I'M GETTING BORED. MIGHT GIVE IT A 2",4" DROP LATER BUT HEN I GET SOME WHEELS.
the 2" drop shackle kits for the 07-08 NBS wont work for 09? Think it would be the same, Summit has them for like 60 bucks.
THANX......... WEEKEND IS HERE AND I WANNA DO SOMETHING PRODUCTIVE. I'LL CHECK OUT THE CUSTOM SHOPS IN HOUSTON AND SEE IF I CAN FIND SOME OR JUST REMOVE THE BLOCKS.
in theory - less axle wrap due to minimized cantilivered length -- if you have a rear jounce bumber - check clearance prior to removal
HUH?
  • 2 months later...
I took the blocks out of my 09 SD and I was very pleased with the way it leveled out. It only took about an hour so you might want to try that first. It's easy and free.
HOW ABOUT TURNING THE CAPS OFF TO START, CALL SOME COMPANIES TO GET A STRAIGHT ANSWER SINCE YOUR BORED! :rolleyes:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
