Wanted to get your opinions on what to do about my cab corners. They are shot. The drivers side is through and the pass. side is getting there. I figured it would take a decent bit of bondo work to fix the drivers side because its workin its way towards the front of the truck. I can handle the bondo work but I'm concerned what it would look after I repainted it. Unless I painted the whole truck I'm afraid it wont match well. One option i was throwing around was maybe getting either black or color matched rhino lining up to the chrome molding or to the body line. The truck is white so I'm just trying to see what my best option is. Even if I went the best way and cut and welded in new cab corners I still have the paint issues. Any ideas?
now adays any good body shop can blend your paint job to look good. Youll never know it was repaired
A lot of people do the rhino thing. I ran it up to the bottom of the chrome on my truck just for protection. The black looks good against the white.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
