Rc 2" Kit Installed Today
2010 Sierra
-2" Rough Country Spacer
-275/65/18 Hankook Dynapro AT RFM Tires
-18x9 Moto Metal 957 Rims
Didn't really follow the instructions for the install, figured there had to be an easier way, and there was. Was done in about an hour.
All I did was:
-Remove bottom strut bolts
-Remove sway bar nut
-Use a bar to get the spacer in
-Line up holes and bolt together, easy as that.
Very happy with the results, makes the truck look a lot better IMO. Fell free to give your input.
any close up on wheels? I did same thing as u but i popped the upper ball joint loose. took me 40 mins with pulling and putting tires back on In a drive way
I can take some close ups this morning.
Here's a close-up of the wheels. Keep in mind this was before the RC kit was installed to see how much lift I needed to prevent rubbing.
  • 4 months later...
I don't have a side view photo currently because the stock wheels are on my truck for the summer. I'll get back to you in April on that haha, but in my opinion they don't stick out "bad". If you drew a straight line from the wheel well to the ground I would be surprised if they stick out an inch.
Looks good. Need to take that air deflector off the front under the bumper so it looks a little higher. Gives you alot more clearence as well.. that thing acts as a plow if you go through any water when offroading. Im installing mine tomorrow thanks for the tips. I'll put some pictures up when im through.
Leveling kit installed today.. pretty simple thanks for the tips. Here are some before and afters:
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,066 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
