03 Silverado-- L0w Idle & Stalling
2003 Silverado Ext Cab 5.3l engine
81K Miles
Stock configuration
In the last month, noticed that idle is lower than normal. In Park or Drive when stopped at a light, the idle gets pretty rough and stays around 300-400 or say and often stalls when turning a corner as well.
Always have the A/c on as I'm in Florida. At speeds of 15 MPH up to highway speeds, all is good. A/C blows cold and engine runs fine.
Stalling 10 times in 30 minutes, at red lights, etc isn't normal though. Last week, my battery died and with a boost I was back up, but while driving and slowing down for a stop sign or red light, the idle drops too low and she shuts off...
Finally, this past friday the battery was totally dead after testing it at the local Advance Auto Parts. Bought a new battery and she starts fine now, but still has the stalling & LOW RPM issue.
I metered the battery with the engine off, on (with A/c on & off)
Engine Off: 12.79 VDC
Engine ON/Ac Off: 13.67
Engine ON/Ac ON: 12.67
These tests though were done without giving any throttle. Please advise me as to what the possible cause is- if this is something you see all the time on this model. Like I said, I'm gonna bring it to check at the mechanic for codes, etc. I just like having an idea b4 going in. Basically, what can be done to raise the idle? I understand that its electronically controlled and I dont see any throttle cable...heheh
Anything I can check, clean, or test in this case...
Thanks and please advise.
Clean the MAF with the correct cleaner and do the same with the IAC and the port. Carbon & varnish build up will cause poor idle. If after a cleanup you still have the problem have a tech check with a scanner. Engine hot in "D" IAC counts should be 15-30.
Beyond the cleaning above, check for an air leak from either a vacuum hose off or a loose clamp, etc. between the airfilter box and the throttlebody.
thanks for the replies guys...new to the newer trucks...
How do I clean the MAF without messing it up? what exactly do I clean..those filaments? What type of cleaner? Etc?
Also, the Idle Air Controller...where is it? Searched all the posts here and googled it too- no pics. nothing came up and I dont know where to look/find the IAC.
For the IAC...what's the Correct Cleaner? And how do I go about cleaning it? Any pics or description of how to find it will be great.
Is the IAC underneath the plastic Vortec cover?
Please let me know - thanks in advance guys!
:devil:
Is your truck also hard to start, especially after the engine is warm? Check the fuel pressure at the fuel rail on the RH side of the engine. You may have a bad fuel pressure regulator (easy, 5-10 minute fix).
thanks for the replies guys....
Just got back from the mechanic. He checked the truck with his computer/obd II machine and spent some good 15 minutes on it.
He said that its clean of codes. He told me he doesnt have the special machine needed, so he reccomended that as the first step I go to a place he reccomends that has this Computer Machine that "recalibrates" or flushes the computer. He said the idle may come up to normal after recalibrating.
He said thats step one- if that doesnt help I should come back..
What do you guys think? I'm here in FL...it's 11:25am and look fwd to hearing your responses so I can make a more informed decision.
Ever hear of such a thing? Computer Recalibration or Flush? Can it ruin anything...or only make good?
thanks in advance...
oh boy! not happy to hear that...
I havent checked the pressure yet. What do I need to do to check fuel rail pressure? Any removal of plastic vortec cover .
its the 5.3l engine on a 2003 silverado.
What tool do i need to find/pickup to check the fuel pressure....
SINISTER- CAN you PM me yer phone # so i can talk to you for a few just so I know what im doing here...
+1
Also I would clean out the throttle body.
Is there any way you can find someone with scanning software and do a basic scan? I would be interested in seeing what your fuel trims are. I think someone hit it by saying a leak past the MAF sensor. If your fuel trims are all over the place showing lean, it is a good indication you have a leak. Take some carb cleaner and spray down the intake past the MAF while the motor is running and see if there is a change in idle. If there is a noticeable change, good possibility you have a leak.
BTW, I woudld clean your TB really well and run some sea foam through your intake and another can through your fuel system. Next area would be your Fuel Pressure as someone mentioned.
Can you guide me in how to get the seafoam Deep Creep Aerosol thru my throttle body.
1. If i completely take off air intake hose from TB, will it stall and check engine light will come on.
2. I have drive-by-wire...is it safe to use deep creep spray from Seafoam?
3. Anyone have a Real Picture of a 2003 silverado 5.3l engine bay they can make markings on to show where to disconnect or drill hole or do something to Properly inject seafoam without me causing any damage....
thanks
DONT DRILL that comment scares me, as for seafoam, I've only used it with the crankcase and fuel lines, but napa or somewhere should be able to tell you exactly what to do, if the counterperson knows anything that is...
thanks
Just disconnect the MAF sensor, then remove the intake tube from the TB.
Crank the truck (it should run maybe not real smooth but it will run) This might set a code just bring it to a part store to reset or let it reset on its own.
There is a small hole in the throttle plate spray it in there.
Load the engine up with the stuff and shut it off.
Hook every thing back up, wait about 10-15 min then crank it up and give it a ride.
Listen to me I hvae been fixing these trucks with this idle stumble and a/c inop since the electronic throttle body came out on the trucks. The throttle body actuator is binding up and causing the unstable idle. I have tried cleanig them and so on with no luck. Replace the throttle body and gasket and take it to the dealer and have them update the pcm to also improve the idle stability. Do this and all your worries will be gone!
    • I have finally paid off my mortgage and can now purchase a new truck. I would greatly appreciate any opinions on the purchase of a new 2026 GMC Denali 5.3L or 6.2L with the Denali reserve package. I am not interested in the 3.0L.  Or should I go buy a Ford?   Thank, John
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
    • New engines will still be using DEF. You just won't have the limp modes occurring when you run out of DEF now.
    • I am not a NOCO fan for a charger I would leave on a battery 24/7. The reason is, it doesn't really float. It waits until the battery drops to a certain voltage and then charges it back up to 14V. It's better than no charger I guess.
