Looking To Buy 1996 3/4 Burb
I am looking at picking up a 96 3/4 suburban 4x with the 7.4L (or a 97, 98, 99). This will be used mostly to haul my comfy butt to work when the snow is too deep for my daily driver (20 mile round trip). I will also be hauling the 3500# boat in the summer behind her. When I tow, it is usually through the hills (remember, I start at 5200 FT above sea level) and go up from there....
Thoughts or concerns specific to the drive train/motor would be appreciated.
--Mike
Hi Mike,I have two Burbs,a K1500(wifey's) and the '95 in my sig.My wife's has almost 120,00mi. & mine has almost 220,000.They are great vehicles.My wife absolutely loves hers,lotsa room,comfy and not too bad on gas(5.7) and has been trouble free since we bought it March of last year.We haven't experienced the dreaded ''4x4'' switch problem yet and hope it never happens but who knows.BTW it is bone stock except for custom wheels.Mine on the other hand is a different story.It's a K2500,lifted,big tires and wheels,a 454,Detroit locker in the rear,4:56 gears....it a beast and I love it.Believe it or not it rides quite smoothly on the highway and steers straight even when towing the toy hauler.Burbs are great at what they were designed to do...haul loads of cargo comfortably.Be sure to buy one built '96 or newer so you get the OBDII system.I would also be sure to get one with the upgraded front axle engagement system,mine has the old actuator(heated gas I believe) and allthough since I replaced it with a new GM unit I've had no probs.I understand under certain conditions the gas inside the actuator can cool down enough to dis-engage the axle.I also understand that the 454s with the OBDII and port fuel injection make a good bit more power than ther older TBI units.Check the front hubs for any play,check the CV joint boots for any tears and grease spewing out.Check ball joints and steering geometry.I would also make sure the rear A/C is working(very expensive to fix,ask me how I know :) ).I think most K2500s have the tow package which will include an aux tranny cooler and na aux cooling fan for the radiator.I would think the PCM will be able to adjust things for the high altitude.That's about all I can think of at the moment,ask way if you have any more questions.
Hope this helps and sorry for the long post.
You're very welcome.As you can probably tell we love our Burbs.I just remembered something I left out...the big blocks have an engine oil cooler also.The lines go to the opposite end of the radiator than the tranny lines and connect to the block right next to the filter.I'm not too sure if the oil heats up the coolant or if the coolant cools the oil,I've thought about having a totally seperate engine oil cooler so the hot oil will have no effect on the radiator.
I actually didn't consider that as my 92 does the same. I was just figuring that it was going to be there since it was bigger than my 1500.
--Mike
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,536 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
