New 4" Lift Kit
great......another $1000 half-@ss lift kit.
spend the 200-400 more to get a real lift that fixes the lower control arm angle and the tire rod angles. you'll get that money back in saving the steering rack&pinion alone (they dont fare to well when the tie rods are on a 45 degree angle)
    MASONV88888888
    MASONV88888888
  • Who's Online   3 Members, 0 Anonymous, 932 Guests (See full list)
    • I have 2 choices.
