Oil Pressure Switch
I put a rebuilt 350 in my truck this past weekend (runs great, by the way) but for some reason the new oil pressure switch I put in doesn't seem to be working right. Before it was replaced it sat at 0 and the Check Guages light would stay lit always (for over 6 years)... now it sits at about 30 and will drop low enough to kick the light back on when you are sitting at an idle while in gear. I will say that it works better now than it did before, but its still not working right. Any idea what I could check to see what's causing it not to read right? It's a Delco switch and it matches perfectly. Not sure what the issue could be unless the guage doesn't work right... it's a 90 Sierra 4x4 automatic. Thanks in advance for any help!
I'd look into the gauge. Also check your wiring. Are you sure you've got the correct replacement part with the correct pressure range?
I'll look and see if there's a way I can test the guage's functionality. As far as the switch itself I believe it to be correct; I know they changed from year to year (the 89 the motor originally came out of had a two terminal switch; mine has 3) but as far as range, I don't know if it's right or not. Something to look into apparently. As big of a pain it is to change I almost don't want to mess with it, but at the same time I'd like to know what's going on with my engine especially since it's new. I'll look into the range of the switch and see if it's the wrong one. I should still have the part number somewhere...
Thanks for the advice!
  • 2 months later...
Did you ever figure out what the problem was?
On my 97 Yukon (5.7) the oil gauge acted the same as yours.
When fully warmed up it dropped to zero and the "check gauges" light would come on at idle.
Any increase in RPM would raise oil pressure and turn off the light.
Recently, I swapped in a new sending unit hoping to cure the problem.
Now, the pressure reads lower and drops to zero as before.
Anybody have any idea what else I can do to make this annoyance go away
Big John NYC :cheers:
No, it's still doing the same thing and I've yet to figure out what it is. Yesterday on my way home from NW Arkansas ALL the gauges except for the speedo went haywire. The voltmeter dropped to around 9, temp was fluctuating back and forth from one side of 210 to the other, the oil pressure sat at 0 constantly, and the gas gauge was reading lower than it should with a full tank. Killed it going down the interstate and started it back up and all was well. Did it maybe 3 or 4 times but it hasn't done it since. I'm having intermittent knock sensor problems and I thought it might be related to that but I have no proof behind my theory - while driving home at 75 mph with the cruise set, the SES light came back on and it lost power as usual, but the gauges remained normal. At this point I'm guessing its the gauge but unfortunately I haven't been able to find one to replace it with. At least not new anyway.
In the truck the motor came out of it did the exact opposite - sat maxed out at 80 no matter what. It was an 89 so the leads were different therefore I wasn't able to test the switch in my 90. With that said, can I try swapping clusters from the 89 to my 90 and check it that way to determine if it's the gauge? Is there any difference between the two?
I am kind of the same issue, even whenthe truck is off the guage sits at 30 and them when cranked it is pegged at 60. The Temp guage has a similar issue but it isn't pegged high. It just never goes to 0. I just replaced the Dizzy, rerouted most of my vac lines, replaced the sending unit, switch and fitting. By the way I have an 85 GMC Sierra 5.7l 350
I decided last night I'm going to tear the cluster out of the 89, swap odometers, and put it in the 90 to see what happens. I'm curious about the oil pressure gauge AND the fuel gauge since it doesn't work right either. That will at least help me determine whether it's the sending unit or not that doesn't read right (full tank = approx 1/4). And not only that, it's in better shape anyway. The plastic cover is near flawless; mine's all scratched up. Wish I could find a 91 tach cluster... that'd be even better!
without the Oil Pressure Switch to provide the essential data to the engine computer, some engine parts might end up damaged. This switch is one of the parts that car owners must check on a regular basis
I'm not sure this one is new enough for the oil pressure to matter to the computer. Before I replaced the motor, it had NO oil pressure according to the switch (sat at 0 all the time) and it ran like that for over 7 years without a problem. This was also a motor that had been driven with the number one cylinder dead for over 15 years. This thing went through hell but was still running - and probably still would - without a hitch or a hiccup ever. But it was slow, shaky, and would fog any mosquito colony within a 5 mile radius. :fume:
Interesting factoid for the day: so this morning on my way to work, no less than 100 yards from the house, it hiccuped real bad - nearly died - and I noticed at that time the idiot lights and gauges were going crazy, and the voltmeter was reading about 10V (it was the only one working right). It was also idling higher than normal. I killed and restarted it two or three times and it didn't fix it like it had before... until it warmed up. I got almost to work; sitting in traffic I decided to try one more time and afterward I had 14V like normal and all was well. Left to go to lunch and it did the same as it did this morning. It even died this time when going from Park to Reverse. Kept on all the way to the restaurant; after I got there I shut it off and restarted and it was fine, and it did fine on the way back after sitting for about 45 minutes or so.
Long story short, I think it's a wiring problem somewhere but where I don't know. I put a new starter on back in July and no problems until two weeks ago so I'm wondering if I have a loose wire on it somewhere. But that doesn't explain the temperature thing to me - it doesn't do it when it's fully warm, only when it's cold. I also have a knock sensor issue but have been too lazy to crawl under it and replace it yet... surely that wouldn't cause this issue though I wouldn't think. Anybody got any ideas or seen this one before? I haven't ruled the alternator out either, FYI. The only thing that makes me think it isn't the alt is it's been a sporadic thing, however I'm beginning to think that's changed now. I've got an extra one so if it comes down to it I'll just swap them out no harder than it is.
Reminder - 1990 truck with a 1989 TBI 350 that's been rebuilt but still completely stock, and hasn't had any issues until this came about. It's still drivable, it just worries me. I'm going to look over all the electrical connections this afternoon after I get it home to make sure nothing's worked its way loose since so many of the clips broke when I swapped motors.
Not cool. What was it doing chrono? It's doing OK now; I guess it was just a fluke? Been running fine the last week and a half or so, although the voltmeter now sits well above 14. It isn't getting into the red though so I guess it's OK.
  • 4 weeks later...
Quick update... so I was under the truck the other day and happened to notice that there is an oil pressure switch located on the oil filter housing that I sure don't remember seeing when we swapped the motor. Now... interesting thing is, my truck is a 90, the motor came out of an 89, but mine's 4WD where the 89 is a 2WD so I had to take the oil filter housing off of my old motor and put on this one because of the torsion bar. That switch was already on there which means that there has to be a wire somewhere that goes to it, only trouble is I can't seem to find it. The wiring diagram in Chilton's is NO help; basically useless if you ask me. I can plainly see the wire on the harness of the 89, but it's nowhere to be found in that same location on the 90 (but there's not a 350 in the way in the 89 either). Anyone have a wiring diagram, know where I can find a decent one, or perhaps know where this wire might be hiding?? It's a flat-blade connector similar to the temperature sensor, and on the 89 harness it's tan/brownish colored...
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,463 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
