MelLandry Posted April 17, 2008 Posted April 17, 2008 I have a 2008 Silverado LT1 with the non-bose system and no navigation. We're AT&T wireless customers with no interest in changing to Verison to take advantage of the OnStar hands free system. So... my question is... What are you suggestions for adding hands free calling to my truck? I want it to be as integrated as possible, but I'm willing to make concessions to avoid placing any visible input devices in the cab. My only firm request is to be able to hear that phone over the stereo speakers. I don't really need any fancy voice dialing or the need to use any existing buttons in the truck to control the calls. I'd prefer it to be bluetooth to avoid the need to have another wire running across the cab. If anyone could get specific product recommendations, I'd appreciate it. Thanks for your help.
omegafiler Posted April 17, 2008 Posted April 17, 2008 You'll just want to search around for BT hands free cell kits for various vehicles, such as the Parrot systems. You may also want to check out Costal Tech. They have a lot of stuff for the 900 series, including an adapter that easily integrates your separate BT kit (ie. Parrot) with the Onstar speaker phone system. http://www.coastaletech.com/ http://www.coastaletech.com/onstar.htm
MelLandry Posted April 17, 2008 Author Posted April 17, 2008 You'll just want to search around for BT hands free cell kits for various vehicles, such as the Parrot systems. You may also want to check out Costal Tech. They have a lot of stuff for the 900 series, including an adapter that easily integrates your separate BT kit (ie. Parrot) with the Onstar speaker phone system. http://www.coastaletech.com/ http://www.coastaletech.com/onstar.htm Oh that's awesome... thanks. Does anyone have a suggestion on what is the simplest bluetooth kit that it would work with (I don't mind continuing to use the phone to dial)? The phone (for reference) is an AT&T/HTC Tilt/8925 Does anyone have personal experience with the coastaltech pins and bluetooth kits? Will I still need to run a power wire for the bluetooth kit?
FirehawkZ71 Posted April 17, 2008 Posted April 17, 2008 This is the one I have it's has a battery that needs to be recharged but works good. Speaker isn't that great. Motorola HF820 You'll just want to search around for BT hands free cell kits for various vehicles, such as the Parrot systems. You may also want to check out Costal Tech. They have a lot of stuff for the 900 series, including an adapter that easily integrates your separate BT kit (ie. Parrot) with the Onstar speaker phone system. http://www.coastaletech.com/ http://www.coastaletech.com/onstar.htm Oh that's awesome... thanks. Does anyone have a suggestion on what is the simplest bluetooth kit that it would work with (I don't mind continuing to use the phone to dial)? The phone (for reference) is an AT&T/HTC Tilt/8925 Does anyone have personal experience with the coastaltech pins and bluetooth kits? Will I still need to run a power wire for the bluetooth kit?
sam5828 Posted April 17, 2008 Posted April 17, 2008 You'll just want to search around for BT hands free cell kits for various vehicles, such as the Parrot systems. You may also want to check out Costal Tech. They have a lot of stuff for the 900 series, including an adapter that easily integrates your separate BT kit (ie. Parrot) with the Onstar speaker phone system. http://www.coastaletech.com/ http://www.coastaletech.com/onstar.htm Oh that's awesome... thanks. Does anyone have a suggestion on what is the simplest bluetooth kit that it would work with (I don't mind continuing to use the phone to dial)? The phone (for reference) is an AT&T/HTC Tilt/8925 Does anyone have personal experience with the coastaltech pins and bluetooth kits? Will I still need to run a power wire for the bluetooth kit? well the bluetooth lockpick comes with all the power lines and everything you need, you just supply the bluetooth kit. if it helps at all i know a guy that has one and is wanting to get rid of it. you could probably get it for $80 or less if ya want pm me and i will talk to him...
chrisb1 Posted April 18, 2008 Posted April 18, 2008 For 2009, GM will be offering Bluetooth capability on the HD trucks via Onstar Generation 8. The 2008 vehicles have Onstar Generation 7. A possible solution would be the capability to upgrade Onstar from Generation 7 to 8. Keep an open eye to this possible option. The hardware soluitons via Coastal Tech and their associated Bluetooth adaptor is a possibility.
jmac Posted April 23, 2008 Posted April 23, 2008 I am waiting for this item below. http://www.scosche.com/bluefusion
jmac Posted April 24, 2008 Posted April 24, 2008 I have attached another link with more detail. http://www.scosche.com/pdf/Scosche_2008_11...integration.pdf The information sheets says the blue fusion will work on GM factory radios, but must have satellite radio. Does not say anthing about navigation units. My assumption is that it will work on none Nav units.
chrisb1 Posted April 24, 2008 Posted April 24, 2008 It appears like the GMX-320 LockPick. It would be nice to reuse the Onstar microphone in the ceiling rather than adding another.
MelLandry Posted April 24, 2008 Author Posted April 24, 2008 It looks like the Coastal Tech OnStar lockpick is the solution for me. My decision now is on which bluetooth device. The Motorola devices look applicable, but I'd really rather have no external control unit. Ideally, I'd like to have something similar in fucnationality to a bluetooth ear bud. I'd like to use my phone for all of the functions, and just have the bluetooth there as a slave. I suppose I could just hide the control module for the Motorola car kit, but does anyone else have any suggestions.
jfm1982 Posted April 25, 2008 Posted April 25, 2008 I have attached another link with more detail. http://www.scosche.com/pdf/Scosche_2008_11...integration.pdf The information sheets says the blue fusion will work on GM factory radios, but must have satellite radio. Does not say anthing about navigation units. My assumption is that it will work on none Nav units. I guess it uses the Factory onstar Mic ? I think i wil give them a call tomorrow.
walbern1 Posted April 25, 2008 Posted April 25, 2008 Let us know what you find out, I'm interested in this too. Thanks
chrisb1 Posted April 25, 2008 Posted April 25, 2008 I have attached another link with more detail. http://www.scosche.com/pdf/Scosche_2008_11...integration.pdf The information sheets says the blue fusion will work on GM factory radios, but must have satellite radio. Does not say anthing about navigation units. My assumption is that it will work on none Nav units. I guess it uses the Factory onstar Mic ? I think i wil give them a call tomorrow. I read the info at their site. The unit comes with it's own seperate Mic.
Rosedog Posted April 30, 2008 Posted April 30, 2008 I have attached another link with more detail. http://www.scosche.com/pdf/Scosche_2008_11...integration.pdf The information sheets says the blue fusion will work on GM factory radios, but must have satellite radio. Does not say anthing about navigation units. My assumption is that it will work on none Nav units. I guess it uses the Factory onstar Mic ? I think i wil give them a call tomorrow. I read the info at their site. The unit comes with it's own seperate Mic. I put in Scosches univeral BT handsfree kit, man that thing is easy as pie. The separate mic is long enough that I mounted it on my visor, ran it down the pillar, under the dash to the glovebox with enough slack to tie up. It uses RCA cables to tie into your aftermarket deck and comes through crystal clear. On top of that the unit comes with a BT transmitter for other devices so if you DAP/PMP you can transmit through BT rather than the crappy FM transmiters. I paid $90 for mine from Best Buy. I should also mention that I'm using a Palm Treo750 (Windows Smartphone) and it connects automatically and flawlessly. I can't say that though for the Pioneer BT unit that I had paid $200 for to connect into my Premier deck. That thing is crap!
