Jennabear Posted June 13, 2009 Posted June 13, 2009 This question comes up quite often in my PM box and emails, so I figured I would throw out my answers here. Throttle body spacers (TBS) came about back in the time when TBI engines were the craze. The TBS did indeed help the TBIs as they helped to improve atomization of the fuel by changing the flow of air as the fuel was sprayed before the throttle body. The gains are minimal but are still there. The TBS are a waste on the newer engines as the fuel is sprayed after the throttle body. The air is already "spun up" as it goes through the throttle body, so the TBS basically duplicates the effort. The TBS won't hurt your engine however, that being said, some folks wind up having problems with the spacer as it is one more thing to wiggle lose and cause leaks.
02suburbanZ71 Posted June 2, 2014 Posted June 2, 2014 This question comes up quite often in my PM box and emails, so I figured I would throw out my answers here. Throttle body spacers (TBS) came about back in the time when TBI engines were the craze. The TBS did indeed help the TBIs as they helped to improve atomization of the fuel by changing the flow of air as the fuel was sprayed before the throttle body. The gains are minimal but are still there. The TBS are a waste on the newer engines as the fuel is sprayed after the throttle body. The air is already "spun up" as it goes through the throttle body, so the TBS basically duplicates the effort. The TBS won't hurt your engine however, that being said, some folks wind up having problems with the spacer as it is one more thing to wiggle lose and cause leaks. Due to the amount of slack in the drive by cable TB wouldnt the spacer help by extending the cable to reduce slack so it will WOT better? I would think that it would have some hardware benefit to DBC
kstruckcountry Posted June 2, 2014 Posted June 2, 2014 Doesn't work that way, even if it did your throttle can only be open so far (all the way).
BigBlueLB756 Posted April 5, 2017 Posted April 5, 2017 Just as good as running another ground wire from the throttle body. Thanks, Jenna!
