WTB: Overhaed console parts 98 Chevy
Looking to find a button assembly for the rearmost compartment of the overhead center console in my 1998 silverado. I think these units were availalbe from 96-99.
Me Too!! I still have mine but it keeps on falling out,only a matter of time before it gets lost.
 Can you buy these new from the dealer??
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
