Questions About Navigation System
I need to ditch my cell phone nav and get something with a larger screen.
I have questions about the factory nav (non-touch screen).
can you listen to the radio or an auxiliary source while the navigation system is being used?
does GM offer updated navigation maps on a regular basis?
i've looked at a couple of aftermarket systems, but i can get the non-touch factory system for less money, and it keeps the truck looking stock.
is there any advantage to the touch-screen? does it have any features the non-touch screen doesn't have?
I can't answer for the 'non-touch' NAV, but assuming it's similiar to the touch-screen one.....
Yes, you can listen to the radio or aux src when using the NAV system.
Yes, GM does offer regular updates (usually yearly) but at $200 a pop. eBay is usually cheaper, but you have to ensure you purchase the correct maps for your NAV system (apparently, not all created equal).
Hope that helps.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
