2001 Yukon Xl Computer Climate Control
My 2001 Yukon XL 2500 HD 4x4 6.0L V8 is equiped with Electronic Climate Control System with a front and rear control console. The system works with the front control console, but the rear control console is not working. The rear control console appears to have no power. I've checked all the AC related fuses located in the Instrument Panel Fuse Block and the Underhood Electrical Center. All the AC related fuses appear to be good.
I have a set of GM service manuals, but they're not with me at the moment.
Does anyone have any troubleshooting suggestions as to what I should check to resolve the issue of the rear control console?
Regards to all.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
