Need Some Help
Hi all,
Looking at a 2006 GMC 2500HD at a dealership right now.
Crew cab, short bed, 6.0L.
1) How long is it? Overall length from the front bumper to the back, please.
2) What gears should this have in it? Dealer website says 3.73 but guy was telling me 4.10 on the phone. I guess I'm interested in the 3.73 for the gas mileage and little towing I do...
Thanks for the quick replies,
-Steve
Best bet is to go to the dealer and look at the glove compartment lid. If you find GT5 behold a 4.10 if you should find only a GT4 you have a 3.73.......another code to look for would be G80 which is the locking rear or posi-traction unit to most. Just some bonus info. Oh if its a 2500 and has the 4L80E transmission which it probably does. Safe your self alot of cash and spring for a big transmission cooler. I have the same transmission in my trucks and they do not like heat. Go with somebodys big cooler whether it be B&M permacool whoever but get a BIGGER cooler. just my opinion and eperience.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
