Ac Blowing Warm
Over the last 5-7 days my AC gradually started blowing warmer and warmer. Now its basically useless.
Probably coolant right?
If so, is it easy to do myself?
thanks
thanks
When you switch the AC to "on", do you hear/feel the compressor "kick in"? If you are low on refrigerant, the system has a safe-guard in it to where it will NOT let the compressor run if you are too low.
My understanding is that the refrigereant also doubles as a lubricant for the compressor, and, hence, no coolant, no lube, and, after a while no bearings. So it'll stay off if it loses its charge.
thanks
Refrigerant actually, not coolant.
You can get one of those R134a kits and charge it yoursef, but it sounds like you have a leak. Best to have it checked out at a shop you trust and have the leak fixed.
As mentioned, there's PAG oil in the system...if it is blowing warm, don't run it till you have it fixed.
Compressor is not kicking in. Im leaving it off.
So you think that the gradual switch from cold to warm is definately a leak?
Well, if the comp is NOT kicking on, then I suspect refrigerant is low. Could be some other issue as well, but, given the symptoms, low refrigerant is high on the hit list as a first pass.
I agree with ^^^^ . Find a good shop that does AC, and let them diagnose it. Although leaks can be a pain, they have clever things they can do with dyes and things of that nature to get to the bottom of it fairly efficiently and quickly.
AC is one of those things where I find it's best to let a pro tackle it, rather than than ME (for example), crawling in there and fixing 5 things that weren't broken and leaving the original problem 3x worse than it was when I started. (I'm GOOD at that :P )
Just my $0.05.
Unless you want to spend quite a bit on equipment and spend a lot of time reading to learn A/C repair, just take it in as recommended above. I went the route of learning it and buying hundreds of dollars of equipment. I like my independence but it has been somewhat expensive and more importantly, very time consuming. But now I'm at a level of competency to fix the most common problems with a/c. I may be ahead a bit on expenditures at this point and may get quite a bit ahead if I keep the old truck around.
Same thing happened to me in my oldsmobile. Obviously its a completely different vehicle but symptoms sound the same. The compressor locked up and I had to get a new one. It was something like a $500 fix. Hopefully it is not as bad for you.
By the way, make sure the compressor is not locked when the AC is off and the engine is running. I didn't think it would be a problem as long as the AC was off, but it stayed locked and basically melted the belt which ended up snapping on the way to the mechanic. A bit of stupidity on my part, but be careful!
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
