For Sale
I installed the new CCFL Halo Ring Headlights. I have the factory headlights if anyone is interested. Thanks!
Price?
07Black where did you get the 1.5" zone lift? I already installed a leveling kit. 2" in front and 1.5" in the back. Could I install the 1.5" zone lift as well??
Like stated above. They are from Zone Offroad products. And yes you can do the zone body lift as well since it is just a body lift not suspension.
for me the 1.5" body lift is good enough but others say just go with the 3" body lift if you are going to do it.
The reasons I did the 1.5" body lift is because of my exhaust gap. I was able to adjust it to look ok with the this kit but if I did the 3" I would have to redo my exhaust. And the other reason is for garage door cleanance. And last reason is because I just bought 33" tires and if I bought the 3" body lift I would want 35" tires. So I took the cheaper route and got the 1.5" kit.
I get alot of comments on my truck with this set up as how it is the perfect combination with lift and tires. I also got an offer on my truck when I was at my local 4x4 shop today, It was tempting but I declined!!
  • 3 weeks later...
They come with Light Bulbs installed in them already. As far as the old headlights go. I was cleaning out the garage. I got tired of looking at them and threw them away. I have 5000K HID installed in my headlights.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
