Amp Performance
Anybody made any pusrchases from AMP Performance. They seem to have pretty good prices on Corsa Exhaust Systems($843.00.+S&H) Just thinking about an exhaust.
Bump
Nobody, all the people looking at exhaust and nobody including myself has heard of these guys. There website said they were in Arizona. I think they specialize in Ford Stuff but sell Corsa. If I get serious, I guess I will give these guys a call and see if they answer their phone.
Actually that would be a good idea to see if someone actually answers the phone. Can't say that I've heard of them. :lol:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
