Oem Keyfob?
piceked up an 04 yukon xl 2500, i guess it came from auction and i dont have either one of the remotes or clickers to lock/unlock.... do i have to go to the dealer for theres fob things, or is it something i can just find on ebay and program, thanks
eBay should produce sufficient results....
So if i find or get the driver and #2 passenger controls, than do i have to go to the dealer and get a program or something.
Did your vehicle come w/ an owners manual? If so the instructions will be in the manual....if you don't have an owners manual you can download an electronic copy of it from http://www.gm.com/gmownercenter/ or do a search here....I've seen them mentioned on occasion....but nonetheless a visit to the dealer isn't required.
Programming instructions do not come in the owner's manual. The dealer wants their $$$ to do it.
But it is simple:
1) Close all doors and insert key in ignition
2)Hold down UNLOCK button on door panel
3)Turn ignition ON, OFF,ON,OFF. Release UNLOCK button on door panel. Door
locks should LOCK then UNLOCK indicating the vehicle has entered programming
4) Hold down LOCK and UNLOCK on the remote for 15 seconds. The doors should
LOCK then UNLOCK
5) Repeat step (4) for each additional transmitter (up to 4 total)
6) Turn ignition ON and OFF to exit programming. Verify function of remotes.
You can get the fobs of eBay, they're everywhere. However, you usually won't have a choice as to which number is on the back of the fob (#1 or #2). You can also get them in any condition; anything from as-is (heavy wear) to brand-new. The places that I've ordered from came with programming instructions but it's been covered here.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,143 Guests (See full list)
