Exhaust And Leveling Kit Done....
Well guys picked up the truck from the shop yesterday and they got the catback dual flowmaster exhaust done and the leveling kit! Neither me or the shop were sure if we could fit the 285/75/17 terra grapplers with an aftermarket wheel with different offset so we ordered them and its just not gonna happen without major trimming so we ordered the 285/70's and hopefully we can make those work without having to lose the mudflaps or doing to much trimming. The truck sounds awesome! It's the perfect volume for a daily driver. Has a nice growl to it but isn't too loud inside the cab. Very impressed with it. And the levelling kit looks great too. New tires should be here monday!
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
