What Has The Same Tread?
ippielb
So, i bought 4 Goodyear MTR's for $100, they're 235/85/r16. Two of the tires are good, two aren't so good. The person i got these tires from got them off a truck he's parting out, the person who had it before him had broken tie rod, and was driving with these tires for a long time. So there's odd tread wear. So, now i'm looking to buy two new tires to replace the worn two. But the problem is, Goodyear doesn't make these kind anymore, now they're all MTR's WITH KEVLAR. So i'm having problems trying to find these tires. So, now i'm looking for a different tire with the same tread pattern. And sidewall pattern. WranglerMTR.jpg
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 358 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
