2500hd Steering Adjustment Lock
Hi Guys,
I have a 2002 2500hd with the 8.1L.
The truck has a 6 inch superlift (which is closer to 7 inches). I have 35 inch Nitto Mudd Grappler tires.
My problem is with the tires rubbing the sway bar up front when I turn.
I have heard that I should install wheel adapters to push the wheels out about 2 inches, but heard that its not good for the wheel bearings.
I have also heard that you can adjust the steering lock to stop just before the insides of the tires rub the sway bar.
Is this adjustment even something that can be done? If so, can it be done by a do-it-yourselfer?
Thanks.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
